I had this error right after I opened OOB app
Hey Everybody,
I had this error right after I opened OOB app. Can someone give me any help to solve this problem. Thank a lot.
Bye.
sllauncher.exe
Error signature
EventType : BEX  P1 : sllauncher.exe   P2 : 4.0.60531.0   P3 : 4de47a48
P4 : PCSUHelper.dll      P5 : 1.0.0.1      P6 : 4e31b856    P7 : 0001a83e
P8 : c0000409      P9 : 00000000
Reporting details
Error Report Contents
The following files will be included in this error report:
C:Document1adrianLOCALS1TempWER8498.dir00sllauncher.exe.mdmp
C:Document1adrianLOCALS1TempWER8498.dir00appcompat.txt
                                                              Close
Best Answer by Nicke Baker
Answered By 0 points N/A #147328
Hello Acke
Have you been able to use the OOB app successfully before or you have been getting this error since you installed it? You might want to try updating the app and see if that will resolve the issue for the error may be occurring due to the use of an old version of it.
Nicke
Answered By 0 points N/A #147329
Hi Acke Zimri,
 After reviewing details provided by you i guess that problem is regarding some web service. To resolve this problem you have to make some changes in your configuration settings.
 I will suggest you to make this ensure that you should only click on register https in configuration settings this will solve your problem.
Answered By 50 points N/A #147330
I would like to thank everyone, as all of your solutions are great. Nicke Baker, you are right, I am going to be updating the application. Thank you again for helping, and since reading your advice, I am no longer having anymore problems or errors, as you did help me solve my problem. Now I am able to use the OOB am able to use the OOB application successfully.
Answered By 5 points N/A #147331
Hello Acker Zimini
There is another technique you can apply to fix this issue. Visit this Techyv's page and get that technique and apply to solve this problem.
Adobe Reader Error Signature and Error Report Contents
