I had installed 3.0 and it began to show some problems
        I had installed 3.0, and it began to show some problems, and that’s why I wanted to uninstall this software.
But, it did not uninstall successfully. Then, I installed the version 3.01 over the previous one.
Then I tried to uninstall it. And it uninstalled successfully.
I found no problem uninstalling the version 2. Here is the screen shot below-
Alert
Win64 not supported
The author of the package you are installing did not include support for this platform.
How do I remove or uninstall 3.0?
Please help.
