I had a problem with the dvd disk checksum utility
Hi
I had an error when I went to write an flv file clip into DVD. I say that there was a problem with DVD disk checksum utility. What is this and how to recover from this problem? Â
Hi
Hi
This problem is often not raised if all other data is being written then it must write this data as well. The other solution is to use other well known software that are ISO burner and Nero burner. These software provides more robust and dependable burning solution. That is why they are widely use software for burring.
Thank you.
Hi, Margaret R Huling,
Most of the shops store the DVD/CD for long without using them so when they sell them to you the disks have already depreciated. This leads to you getting this error when you try to write data to the disk.
 I will suggest that you get a new disk and try other burning software like NERO or ASHAMPOO
Thanks
Amos Marie
