amb rose
10 points
Posted on - 02/04/2013
Hello experts,
I am using Windows XP with media center edition 2002. I am facing the problem with the speakers, as my speakers are in very good condition but sound quality is not good enough. The bass is very high and voice can't hear properly. Can I adjust the music player in the bass and treble? I think the problem is with Bass/Treble.
I have to adjust the music player in bass and treble
Open Windows Media Player. And click on View > Enhancements > Graphic Equalizers shown in this picture.
It will show these sliders or equalizer to adjust base and treble.Â
Or you can also double-click on the Volume icon located in your system tray. Click Options and then select the Advanced Controls to make it visible in the Master Volume control. Click it to see the Bass and Treble settings.
You can set the Bass/ Treble settings from the sound icon on your system tray. Just double-click on the icon and then, click the Advanced button to launch the Advanced Control for Master Volume. You can adjust the Bass / Treble sound from there.
Another option is to adjust Bass/ Treble from the speaker itself. It is usually located near the power button on your speaker. And lastly, you can go to Control Panel and then Sound and Audio Devices. You can find all the controls in there.
