I have Ads instant hdtv pci code10 error
Hi.  I have a Dell XPS 17 that has a Core Duo processor, 4 GB RAM, 1 TB HDD and Windows 7 64 bit.  I recently lost audio on my laptop and a message pops up that says "ads instant HDTV pci code10 error".  What does this mean?  Please help.
Answered By 40 points N/A #141709
You see this message because your audio system can't start.  This can happen if you experienced a power loss or if you deleted some system files.  In order to fix this problem, you should use system points.  System points are generated whenever you install or remove something.
To restore your system to previous settings go to Start -> Accessories -> System Tools -> System restore.
Now select any system point and click the “restore” button.  I hope I helped.  Regards.
