I Have An Issue While Activating Windows, And It Gives A 0xc004d302 Error; Please Help To Troubleshoot This Error
Describe the 0xc004d302 error? What are the steps to resolve the error code and explain the cause of this error message?
The Windows activation error code 0xc004d302 indicates that the security processor has reported that the trusted data memory has been reactivated. Corruption in the license files, change in the default permission, and if the user tries to run multiple commands without restarting the system, then this is the possible cause of the error code.
The step to fix the error is shown below:
• Open the command prompt and type SFC.EXE/SCANNOW to run System File Checker and press Enter.
• Insert the Windows installation CD if requested, and System File Checker will replace or transfer the missing and corrupted files.
• Run the system in safe mode.
• Scan for the virus or malware by using the anti-virus
