I Have An Issue While Installing Applications, And It Gives An 805a8011 Error
Describe the 805a8011 error? What are the steps to resolve the error code and explain the cause of this error message?
If the user uses the Windows operating system on the mobile device and tries to install or update the application, then sometimes an error occurred named 805a8011 error. The error code usually occurs due to an app connection problem, issues with syncing to Microsoft account, and low storage space. The solution to fix the error code is as follows:
Solution 1:
Change your network.
Try to connect to a different network or Wi-fi.
Solution 2:
Free up the storage space.
Clear the unwanted files and folder from the phone.
Solution 3:
Check the Date and Time Settings.
Solution 4:
Synchronize the Microsoft Account.
Step 1: Log in to the Microsoft account.
Step 2: Go to Settings >> Email+ accounts.
Step 3: Press and hold on Microsoft account.
Step 4: Tap on the Synchronize menu.
Notifications
