I Have An Issue While Installing Windows And It Gives 0x8024400a Error
What is the 0x8024400a error? Why the system can’t update the services and throws this error message? Describe the step to resolve this error code.
0x8024400a error is a Windows update error message that occurs when the user tries to download Windows Update. The error message will appears like “Cannot download windows update error 0x8024400a.” The cause of the Windows Update error is due to various reasons, and those reasons are:
• Programs or processes that interfere with Internet communications.
• Resources issues on the computer.
• High Internet activity.
• Recoverable database errors.
• Interference of Antivirus and firewall.
• Incorrect Windows update data locations.
• Corruption of Windows update Component.
The methods to fix the 0x8024400a error code are:
Method 1:
Easy fix solution.
Step 1: Select Start -> Settings -> Update and Security -> Troubleshoot.
Step 2: Select the type of troubleshooting and select Run the troubleshooter.
Step 3: Allow the service to run and then answer the questions on the screen. The user can also try recovery options or upgrade and installation error code.
Method 2:
Backup the registry files and reset the registry files.
The screenshot of the error code:
