I Have An Issue While Installing Windows, And It Gives An 80200053 Error
What is the 80200053 error? Why the system can’t update the services and throws this error message? Describe the step to resolve this error code.
80200053 error is a Windows update error message that occurs when the user tries to download Windows Update. The error message will appears like “Code 80200053: Windows Update encountered an unknown error.” The cause of the Windows Update error is due to various reasons, and those reasons are:
• Programs or processes that interfere with Internet communications.
• Resources issues on the computer.
• High Internet activity.
• Recoverable database errors.
• Interference of Antivirus and firewall.
• Incorrect Windows update data locations.
• Corruption of Windows update Component.
The solution to resolve the error code is:
Solution 1: Turn off, Windows Defender.
Step 1: Enter the Settings and turn off Defender in public and private networks.
Step 2: Go on the Start button, then type Command prompt.
Step 3: Now, type the command “netsh winhttp import proxy source=ie” and press Enter.
Solution 2: Disable the Anti-virus program.
Solution 3: Using Media Creation Tool.
Step 1: Download the Media Creation Tool.
Step 2: Run the tool and Accept the Terms and Conditions for the application.
Step 3: Select Upgrade this PC option.
Step 4: Once it downloads files, MCT will start applying the updates.
This process will take more than 2 hours, depending on the Windows version and Internet Connection.
Notifications
