I Have Called A Logon Value; And I Face A 0x557 Error Message
What is the 0x557 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x557 error is also known as ERROR_INVALID_LOGON_TYPE 1367 (0x557) error message. 0x5f error occurred when the device core was hung. The debugger has forced the device to a ready state and recovered debug control, but your application’s state is now corrupt. You should have limited access to register and memory, but the device should be reset to debug further.
The symptoms of code 0x557 to dec is the user will get a complete blue screen with the brunch of the words and numbers that will indicate a serious error. The cause of code 0x5f to dec is the BSODs, which is generally caused by faulty hardware or software corruption.
The steps to fix the 0x557 error code is as follows:
Backup the current registration information. Click on the left corner button from your mouse the “charms bar” will appear. Type “regedit” and click on the File menu, then choose the “Export range” option and select “All” in the option, then choose the location for the backup file and name the file then click on “Save.”
View items to delete useless keys unfold “HKEY_CURREN_USER/Software” then find the program name then right-click on it and select the “Delete” option.
Notifications
