You want to update your Samsung galaxy ace phone. When your phone will update its software to its newer version, phone will discard all old software’s and data. In some cases some phone may not delete old software and data.
If you want to update your android OS to its newer version, then it will better to take a backup of your phone’s data. You must take your contact numbers and SMS in backup
If you don’t want to lose your data, after taking a backup, you update your phones firmware.
The Samsung Galaxy Ace S5830 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies measuring 112.4 x 59.9 x 11.5 millimeters and weighing 113 grams. It uses mini-SIM card and has TFT capacitive touchscreen display with 16M colors at 320 x 480 pixels screen resolution protected with Corning Gorilla Glass featuring TouchWiz UI 3.
It ships with Android 2.3 Gingerbread powered by Qualcomm MSM7227 Snapdragon S1 chipset, 800 MHz ARM 11 processor, and Adreno 200 GPU. It supports microSD expandable up to 32 GB. It runs on 278 MB RAM with 158 MB internal storage. The primary camera supports 5 megapixels with AF and f/2.6 featuring LED flash. It can record video in 480p at 24 fps.
There is no secondary camera. It has 3.5-millimeter jack featuring DNSe sound, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 2.1 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML.
It runs on removable Li-Ion 1350 mAh battery with standby time up to 640 hours on 2G and 420 hours on 3G. Talk time is up to 11 hours on 2G and 6 hours 30 minutes on 3G. It is available in black, white, Hugo Boss Edition, and La Fleur colors.
Similar to doing a factory reset, it is wise to back up your phone’s data on a microSD card before doing an update on the operating system.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
