I Have Downloaded Acrobat, But It Throws An Error Saying ‘Acro3D.msi File Is Missing.’
Explain the methods to fix the Acro3D.msi file is missing error? Write the steps to check the error that occurred before performing the methods.
When the Acro3D.msi file is missing from the system, it causes an error with a message ‘Error 1361 – A network error occurred while attempting to read from the file C:\Windows\Installer\Acro3D.msi.’ To ensure about the error, go to the directed location and check Acro3D.msi file is present in the folder or not. The steps to fix the error code are shown below:
Step 1: Open Windows Control Panel and go to Add/Remove Programs.
Step 2: Start the Acrobat X Suite uninstaller.
Step 3: Select Acrobat X Pro through the Acrobat Suite uninstaller.
Step 4: The above action will remove the Acrobat X product and the RIBS installer entry.
Step 5: When the user is ready to reinstall Acrobat, start the Suite installer and select Acrobat X Pro.
