Max Smith
30 points
Posted on - 09/11/2012
Hi Experts,
I have faced problem with my Adobe Flash Player. The application is showing an error message “Error Reports Contents:
The following files will be included in this error report:
C:DOCUME~1OwnerLOCALS~1TempWERe3f4.dir00FlashPlayerupdateService.exe.mdmp
C:DOCUME~1OwnerLOCALS~1TempWERe3f4.dir00appcompat.txt
Close”.
I have nothing to do but close the option.
Is there anybody having idea about this error report?
Please help.
Hi Max,
You can try, Completely uninstall flash player and re install it. To uninstall flash player you can use Revo uninstaller. If you don`t like to use this software, you can use Adobe flash uninstaller. To find that software, go to the link below. Always try, do not disable the update service from flash player.
Good luck
Dear Max Smith,
I think some files may be missing from your install file, or some files may be broken. You should just remove them and use the updated Flash Player. Download the updated file from here : http://www.adobe.com/support/flashplayer/debug_downloads.html. To resolve this problem, just uninstall the previous one and install the updated version.
Thanks,
Max
