I have faced a problem with my Windows 2003 Server
Hi Experts,
I have faced a problem with my Windows 2003 Server running SCCM 2007 native mode.
It has failed to provide recent updates to deploy into the repository.
I have tried several ways to get it ok.
I also visited several sites to get a remedy but no result.
If you have any idea for the issue, please help me to solve the problem.
Thanks in advance.
Best Answer by Brown Dubin
Answered By 0 points N/A #144020
I think some file may corrupted to progress.
You must reboot your system with a fresh copy of Windows 2003.
And after that you should connect the server and it must be in virus protection so first of all scan your system with a updated antivirus and then run the updates for OS.
Hope it will help you.
Answered By 5 points N/A #144021
There are a number of ways to troubleshoot this problem;
  • If you have the necessary Public key infrastructure, apply the necessary PKI certificates to the MP since your MP might be having some troubles.
  • You can also check the MP logs or use the MP troubleshooter and see if it helps.
  • Also make sure that you have a SCCM certificate which has the server authentication and am afraid you will have to ask for the web server certificate again.
Hope it helps
