Hi guys,
I have been using Macbook Pro for long. Recently it has encountered a problem. I have failed to connect my PC to another PC. However, the PC is running with an upgrade version of Macbook (Snow Leopard). I need your help to solve the problem.
Thanks in advance.
Hi. John Griesham
I searched a solution that may help you solve your problem.
1st you got a LAN cables and join 2 pc.
2nd you should connect immediately once you plug in both of the LAN cables. Check your LAN network go to your pc Network and Internet and change advance sharing settings. Everything is turn on. And connect other pc. Restart this 2 pc and enjoy
Thanks
Carrie Westmoreland
