Mia Molly
20 points
Posted on - 01/06/2013
Hi to everyone,
I have to fix opera flash player. My current default browser is Opera; I’m having a hard time reloading the pages that need a flash player plug in such as web browser games. This is acting so strange yesterday; can you help me fix this opera flash player? I tried to restart the PC but still the same problem occurs.
Your suggestion is very much welcome.
Hi Mia Molly,
I believe I will be able to help you with your query to the best of my ability. In order to fix the opera flash player, this is what you need to do;
Try updating the flash software. You may first need to check the version of the flash player.
You can then update by downloading and installing the latest version of the flash player from the Adobe website. This will solve the flash player issues or you may also delete the corrupted files in the flash player directory if any.
Follow the prompts to install and it will now be running on your computer.
Restart your browser and it should be working normally.
I hope this solves your query.
