I have a forum concept web agency idea. First issue is, how do I make a forum which includes images, font styles, etc? Next is, how do I go about finding webdesigners to talk on the forums of the web agency. Have anybody tried this before? Please help.
Wow. Well, it's not an easy process, it'll cost you time and money. First, you get the webspace from whichever host you like, then look for the forum software you want to install, for example vbulletin, IPB, phpBB, etc. The first two are not for free, you buy them from their vendors and install it using their installation guide. PhpBB is an open source project, so you can get it for free from their website: https://www.phpbb.com/ then follow their installation guide, which is provided and there is also massive support for it, so you do not need to worry about it. Then, for the skin part, you'll need a graphic designer who is also capable of coding with PHP. He will make you the skin you desire. You can get them here with a little bit of searching: https://www.deviantart.com/ Also, there are a lot of open source skins for each forum software, which are also provided with their installation guides. I hope I helped a bit.
