I Have Installed A Windows 10; And I Face A 0x80041023 Error Message
What is the 0x80041023 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x80041023 error occurs when the user either update Windows 10 or fresh reinstall the computer system. It can be quite possible that the user has an invalid key or user is upgrading from Windows Home to Windows Pro. The cause of the 0x80041023 error is Windows Key is Invalid, different versions of the Key stored in BIOS, or trying to update from OEM Licenses. The steps to fix the 0x80041023 error are:
Hold down Windows Key + R to open up the Run Dialog box and type “cmd” and press enter. Type “slmgr /ipk <Windows Key>” slmgr /ato and press enter. Once the license key has been changed the restart the computer.
Notifications
