I have installed the sound driver. Where is the sound icon?
I recently installed windows and sound driver. Sound is working properly but I could not find the sound icon in system tray how I can get it.
Hi Dear,
Dear it is very easy to find that icon.
Type “control” in run or click on start button and open control panel.
The control panel is the center of all the computer hardware controllers and software configures.
We can make any change in our computer from control panel.
Choose “Sounds” in control panel.
In sound property windows, click on “Advanced” tab and you will see a check box on the lower area of the window with this statement.
Place the icon on taskbar, just mark in the check box and apply.
You will see that the icon is now placed on taskbar.
Thanks
