I Have Launched An Application; And I Face A 0x8004060c Error Message
What is the 0x8004060c error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x8004060c error mostly occurs when the are some corruption issues with an OST or PST File in the computer system. Sometimes the PST file exceeds its maximum limit, and storage space decreases, thus result in the occurrence of the error. The steps to remove duplicate emails are by default, your Inbox and Sent Items folder to contain a copy of all the emails you send to your partner, and to remove it, you have to go on the Sent Items folder and sort it by the receiver and click on the header to perform the task. The mails can be cleared by automatic settings, and that is as follows:
The alternative method to fix the 0x8004060c error is to download and install the PST Recovery Tool and helps them to recover these issues in the application.
Notifications
