I Have Opened Acrobat, And It Shows Acrobat Exe Application Error
When a doc file is opened in the Adobe reader, and the Adobe Acrobat Reader Crashes, it gives an Acrobat exe application error with the description “AcroRd32.Exe – Application error.”
Now, click on OK to close the program, then click on CANCEL to debug the program. This message is then followed by Adobe Acrobat Reader DC has stopped working. The solution to troubleshoot the above error problem is to reboot the machine or log-off from the user profile, then launch the application as an administrator and update your application to the latest version and to check for updates, click on help >> check for updates. After installing the updated version of the application, reboot the system, then launch the application and go to Edit >> Preferences >> Security (Enhanced) >> uncheck ‘Protected Mode at startup’ and ‘Enhanced Security’ >> Click on OK and restart the application.
If the problem continues then download and install Adobe Reader and Acrobat Cleaner Tool from Adobe Labs.
