I have a Plug In Question
I am a mac user and working in Illustrator CS4. I screwed something up with the program – when I open an Illustrator doc I get an ERROR message that plug ins are missing (Calligraphic Brush Tool & Offset Path). And I can not access my tools.
The document SCHEDULE.ai’ contains elements that are managed by plug-ins that are not
currently available. You can delete or expand these elements but you cannot manipulate them in other ways. The missing plug-ins are listed below.
Adobe Calligraphic Brush Plugin (CalligBrushTool.aip)
Offset Path (OffsetPath.aip)
Calligraphic Brush (CalligBrushTool aip)
Don't Show Again
OK
Please Help.
Best Answer by Chalk Talk
Answered By 5 points N/A #124126
Actually what you may have done is accidentally deleted those graphics from your computer which are important for Illustrator CS4 application. The workaround to that issue will be as follows;
You will need to open Illustrator CS4 and then try running its update checker and see if it will reinstall the missing plugins.
In case that does not work, then you will just need to go to the control panel and uninstall Illustrator, and then get the setup that you used to install it and reinstall the application. All plugins will be installed after you reinstall the illustrator application.
-Chalk Talk
Answered By 0 points N/A #124127
Hi
Illustrator C4 is one of the great soft in the category which helps to design vectors with independence. You are facing problems in it. The program must have problems in its core files. Or the installation files somehow became corrupted. Reinstall may solve the problem. You can also repair the corrupted files to solve the matter.
