I have a problem with C:Documents and Settingsdev3Desktop>java Test
Hi Experts,
I have a problem with C:Documents and Settingsdev3Desktop>java Test. An error message indicates that “Error: could not open `C:Program FilesJavajre6libi386jvm.cfg”. I installed java 1.6_11 and for better reinstalled 1.5_11.
Have you any idea regarding this problem?
Please help me.
Answered By 590495 points N/A #136531
If this is the first time that this happens, try restarting your computer then try it again. Restart whatever it is you are doing after rebooting your machine then see what happens. If this doesn’t help, you should check again the compatibility of the software with your computer by checking its system requirements. Your computer should first meet the necessary system requirements of the software before it can actually work.
You can check the system specifications of the software on the website where you downloaded the installer. The site usually lists the important information about the product like its system requirements, tips, supported file types [if applicable], frequently asked question [FAQs], major features, functions, and others.
