I have a problem with fifa 11 summer patch download.
thomas 10 points N/APosted on - 12/26/2012
Hello friends,
I have a problem with FIFA 11 summer patch download. The game client cannot continue the downloading process; I cannot see an error message, it just crashes and never responds in the computer system. My current Os is Windows Xp. I hope you can find a way to help me regarding this issue.
Hi there user:
It could be the client problem which is resulting into crash. It’s a headache if you stick with it. Nobody wants to babysit an issue like this. I recommend that you clean all the files or tools associated with the game. Here’s the link where you can download FIFA 11 for free from another download client. https://fifa-11.en.softonic.com/download
If you play FIFA 11, make sure your computer meets the requirements. FIFA 11 supports Windows XP Service Pack 2, Windows Vista, and Windows 7. It requires 1.8 GHz Intel Core 2 Duo or faster processor, 1 GB RAM, Microsoft DirectX 9.0c-compatible video card with 256 MB video RAM and supports Shader Model 3.0 or higher, sound card, and 6.5 GB free space.
FIFA Soccer 11
If you are using Windows XP but you are not using Service Pack 2 or you don’t have a Service Pack at all, download Windows XP Service Pack 3. This is the latest and last Service Pack update for Microsoft Windows XP. Now, if the game is working fine and your problem is only with the patch, try downloading FIFA 11 Patch 1.01.
This patch was released on October 28, 2010 for PC and contains a wide range of improvements for your game.
1....
