I need someone who can help me because I have a problem with Iphone 4S and am wondering whether anyone else is experiencing the same. A sign like this !, red in colour gets displayed every time I send a message.The text does not get sent unless I switch the phone off and then start it on once again.This persists even after making some attempts to shut the program down.
I have a problem with iPhone 4S
This sign comes up in your Message application if the message was not sent successfully. Make sure you have enough network coverage in the area so as to not have a breaking signal on your mobile phone. If you are using iMessage, make sure your internet connection to your phone is connected and is working. If these two factors are actually not at fault, you have a good network coverage or your internet connection is working and the mobile phone has a stable wireless connection, then you may need to reinstall your iOS as the software may already be corrupted. Try and test again after reinstalling your software, if it's the same, take the mobile phone to the store to have the hardware itself checked.
