I can use the Crossfire on my HP Pavilion Dv6 without issues. They are compatible according to my research. But when I try to enable it, it is saying something about monitor compatibility. I'm not sure about the default screen setup. Also, I'm not sure if my motherboard will work just fine with it. Can anyone give me some insights about it?
I have a problem in my AMD Crossfire
Before you enable your graphics card, check and make sure that your computer’s display is running with the most appropriate resolution. Check your monitor’s output resolution. If it is set to the lowest, try to increase it. And if it is set to the maximum try to decrease it. Only increase or decrease the resolution by one level each time you adjust it, so you get the right balance where the Crossfire would work.
You can find your monitor’s display settings by right-clicking the desktop and clicking properties. See the screenshot below for more information where to find the display setting.
