Jai Zadok
60 points
Posted on - 09/26/2012
Hi guys,
I have a problem with my Internet Explorer. It is throwing the error message as attached below.
I want to get a remedy on urgent basis.
Please help.
Ssvagent.exe – Entry Point Not Found
The procedure entry point_resetstkoflw could not be located in the dynamic link library msvcrt.dll.
Good Day Jai,
I have encountered this error once and what I did was update my JAVA to the latest version. Here are simple steps to solve this Internet Explorer error:
1. Download the latest JAVA update through this site: http://www.java.com/en/download/index.jsp
2.. Uninstall JAVA installed on your device. Uninstall all of its components through the ControlPanel.
3. After Uninstalling, Restart your device.
4. Now, Install your newly downloaded JAVA installer and wait for the Installation to finish. Then again, restart your device.
5. That's it. Problem solved.
