I have a problem with my keyboard
I have some problems with my keyboard. Since last day it works properly, but today it show some problems with keys.
The problem is, when I try click a letter it is showing some other numbers.
I can't understand it why, Please help me with this.
Answered By 0 points N/A #136494
It usually happens when something spills on the keyboard. It causes when we try to type one character, it produces random characters or the characters produce directly above or below them.
Clean your keyboard with dry paintbrush, so you can easily remove anything stuck under the keys.
After clean the keyboard, now you take a check on keyboard. Type the keys on laptop. If the keys are typed in normal the problem solved otherwise if the key types wrong letter then you have replaced your keyboard.
If you cannot get keyboard properly then you can use wired/wireless keyboard or on-screen keyboard.
