I have a problem with my Mac OS x internet explorer themes.
Hello experts,
I have a problem with my mac OS X internet explorer themes. Those themes for my internet explorer are all non working themes. I tried to apply it but nothing happens. Is there a compatibility issue between my operating system and my themes? I hope you can give me some idea.
Thank you.
Best Answer by Cohen Wible
Answered By 0 points N/A #151103
I will help you to solve your problem. As you are running Mac OS X, you should know that there is no Internet Explorer available for Mac. It is a browser in Windows. Mac has Safari web browser and if you are trying to install themes in Safari , then you cannot do that. Safari does not support it. You can do that in Mozilla Firefox.
Answered By 0 points N/A #151104
If you are looking for internet explorer themes for Mac OS X, sorry to say as there are non available in the internet. The graphical user interface for Mac OS X is standard for all their applications as it is embedded on their system. You can only apply themes in the windows or linux environment, as there are third party applications dedicated to supply you with your need. If you are using a windows based or linux based operating system, I would suggest you using Stardock products as they have a wide range of applications to support not only themes but the GUI of your system.
Hope this helps!
