I have a problem with my Samsung Galaxy Tab 7.0
I have a Samsung Galaxy Tab 7.0, now I am in a big trouble. While I was playing a game it suddenly become full black. Screen went out black, But its keys have some lights on it. Please help me with this, this is my new tab.
Hope someone will give me solution for this.
Best Answer by Muliyati
Answered By 0 points N/A #135446
Samsung acknowledged there are few problems in tablet Galaxy Tab. This problem appears when the Galaxy tab is running a number of Android applications.
Screen resolution of 1024×600 Galaxy Tab to reach can not run multiple applications on the Android Market to perfection. Therefore, applications are only able to perform at a maximum resolution of 800×400.
If you download the application to the Galaxy Tab Android Market, some applications are not scaled properly
so i can only advise you to upgrade your Galaxy Tab or reset your Galaxy Tab and then on again.
can also choose a lightweight application that the resolution in order not to burden the your Galaxy Tab
It only solution i can give
Answered By 0 points N/A #135447
Samsung acknowledged there are few problems in tablet Galaxy Tab. This problem appears when the Galaxy Tab is running a number of Android applications.
If you download the application to the Galaxy Tab Android Market, some applications are not scaled properly (on screen)
It only solution i can give.
Answered By 0 points N/A #135448
Screen resolution of 1024×600 Galaxy Tab to reach can not run multiple applications on the Android Marketto perfection. Therefore, applications are only able to perform at a maximum resolution of 800×400.
so i can advise you to upgrade your Galaxy Tab or reset your Galaxy Tab and the on again
