Today I encountered a problem. I just downloaded the latest version of nRoute. I am trying to run this by installing it. But here I get an error message and that is:
"There is a problem with the nRoute registry. Please re-install the nRoute and start it again."
I have also visited some sites and forums to see if they have a solution to this problem but in vain. So, I need some suggestions on how to solve this issue. I will be glad for some insights. Thanks.
I have a problem with nRoute installation
I will give you possible solutions for your problem 1. Please update your antivirus and have a full system scan ( You must have a Good and trusted antivirus I recommend using kaspersky and Norton) 2. Have a registry cleaner and fixer ( I will give you a link on the program that I am using http://www.piriform.com/ccleaner/download) Please download and install the program and Run it. Click on the registry and scan for issues and it will fix it. 3. Try running it as administrator you can do it by right clicking the application and left click on Run as administrator
