I have a problem of resizing the images
I have a problem of resizing the images on my PC, both from the computer and in URL. Even by the use of Magik Studio, I am not able to resize the photos and an error message remitted is as below.
How can I be able to fix this problem?
Exception 445: unable to persist pixel cache
Best Answer by Elgaothy Carl
Answered By 0 points N/A #149541
Image resizing has become very easy nowadays as you can do it directly online without downloading any software. Some of the best online resizing websites are :
1. www.picresize.com/ (fast and easy)
2. www.cutmypic.com/
3. www.webresizer.com/
4. www.resizr.com/
If you want to do it offline then you can download Picasa. It is easy to use and has a lot of options to customize the image.
Hope the information helps you.
Answered By 5 points N/A #149542
Hello Annelforth,
I researshed on the problem faced by you and dinally got to the conclusion that its a generic problem of Magik Studio.
Most of the users are getting the same error in the previous versions too.Seems that it wont be fixed.So i recommend some other source to resize your image, Is still the problem persists then try to change the file format of your image from GIF to JPEG
using any freeware converter available in the market, and then try resizing the image.
