I have a problem in xp occur after installing SP3
Hi Experts,
Problem of installing in XP SP3 occur error installed 360 with Norton. Can you please help me with this. Thanks.
Hi Experts,
Hai Harisson,
I have also experienced the same problem with norton in xp sp3. After installing the norton 360 errors are apperaing…
I researached a lot i cant find a perfect solution. Now from this site i got the information what i was looking for the past 3 weeks.
The errors are really annoying one. Thank you so much fritz. You really helped me in this bad problem. And many thanks to the techyv.com experts to open a site like this to solve the problems.
I really love this site.
Again Thank you so much to all of you…!
Here are the prerequisites if you want to update your operating system to Service Pack 3. If your Windows XP is not running on any Service Pack, you need to update your operating system to Service Pack 1a or Service Pack 2 before installing Windows XP Service Pack 3. This is required.
But if your Windows XP is running on Service Pack 1 or Service Pack 1a, you can proceed on installing Windows XP Service Pack 3 without installing Service Pack 2 first. Also, before installing Service Pack 3, check if you have the following updates installed on your computer:
If you have one or both updates installed, you need to uninstall them first prior to installing Windows XP Service Pack 3. Click “Start”, “Control Panel” then “Add or Remove Programs”. Scroll down and select “Microsoft Shared Computer Toolkit” or “Remote Desktop Connection” then click “Remove” and then follow the instructions.
If you have Norton 360 installed before installing Windows XP Service Pack 3 and it stop working after the installation, just uninstall and reinstall the program. This should fix the problem.
