I have a e71 mobile, recently I am experiencing some issues with my phone.
The problem is when I use my phone, some times it goes automatic restart. By this I am having lot off time loss.
Some one please give me a solution for this.
I have problems with my E71 mobile
hi
try this solutions.
hope this would help!
These three easy fix steps prove to solve more than half phone problems :
Easy fix 1: Properly turn off your mobile device, after a few minutes from taking the battery out, put back the battery and turn on your phone. You can press the power button till it vibrates if you have a phone with irremovable battery.
Easy fix 2: Restoring back the factory settings. Backing up all your data’s are always highly recommended.
Then go to Menu > Tools > Settings > General > Factory settings or Menu > Settings > Phone > Phone mgmt. > Factory settings. Refer for more information on your phones user guide minibook.
Easy fix 3: Make sure to update your phones software. Often we don’t get to update our phones for most recent software. Make back up for your phones data, contacts first and the update would just be a maximum of 15minutes.
Many Nokia phones can update automatically: select Menu > Settings > Phone > Phone Updates. See how to update your phones software if this option isn’t available on your phone or if you need more help.
Commonly reported problems includes sound problems, blank display, application failures, phone lock-ups and other should be an easy fix issue. Nokia says that usually these problems can be fixed by the user in just minutes.
