I have questions about Micromax mtv mobile x505
I have a 2.8" Micromax Psych x505 MTV-inspired dual SIM mobile phone.
Is the touchscreen really not that responsive and accurate?
I really have to press hard on the screen for it to respond.
Is there an option for the sensitivity?
I need help with my Micromax MTV mobile.
Answered By 0 points N/A #170418
Hello Edward,
Try going into the setting's menu on your phone and see if you could change any settings regarding Touchscreen. If you don't find anything related to the screen then probably it is not possible manually to reconfigure it.
Also try looking up the user guide given at the time of purchase of the phone.
Generally in capacitive touchscreens when you touch the screen a connection is setup with the capacitors which respond to the negligible amount of current passed.
Hence, I think there must be some problem with your touchscreen and a few of the capacitors might have discharged. Consult the nearest service Centre regarding this and then decide.
Cheers.
