I have a really big problem with Adobe Illustrator
Hello Guys,
I have a really big problem with Adobe Illustrator. Every time I click a Color, it would result in a different one. For example, clicking the yellow artwork would result in red. This started when I used the “Save for Web” command.
I think some configurations went wrong so I tried fixing it by reverting back to default settings. Upon pressing CTRL ALT SHIFT, everything went worse. Now, there are missing options on the tabs in the panel.
At this point, I am hoping someone can give me a solution. I can’t work like this. I would really appreciate your help since I am at my wits end.
Thanks!
