I have received an error message by the embedded eval kit
Hi Experts,
I have received an error message by the embedded eval kit. It indicates “Code Generation Errors” “Error Code 7 (refer to details)” “Error Code 1 (refer to details)” while trying to accumulate a vi. I also received the same error messages from the tutorial exercise 2 while accumulating vi.
I found that the version of the FPGA module is 8.6. It was installed by the DVD supplied with the eval kit. I also renamed the above mentioned two directories.
Do you have any idea regarding this issue?
Please help.
Answered By 10 points N/A #135099
The errors you encountered seem to be due to an internal error in the software. Internal errors are caused when some critical files of the software are missing or when they are corrupt. So try to reinstall the software and then try the process. You could try the following steps:
  1. Uninstall the software from your computer and reinstall it on your computer.
  2. Make sure you select the correct version of the software that is compatible with your system.
  3. Follow the instructions on the screen and setup the software.
  4. Check the file path and make sure it is correct. See the file path in the settings of the software and then verify it by checking the folder on your computer.
Hope this information helps you.
