I have a simple HTML question
I have created a HTML file and put it in my E-Mail signature, but I do not want it to be displayed as HTML. I can not make it work . Can someone please help me?
Hi Lynn,
What email are you using right now? If it is outlook kindly open your notepad and copy the html you want to display in your email, edit it in the notepad, copy the file you want to be display in your email and paste. If you have a picture attached, you can edit it in the Microsoft Word copy the picture and paste it in your emails. If you are using HTML with your signature make sure you tested it, test it with many emails, some scenarios during 1-2 emails where okay but on the 3rd up some errors occur on graphics. Don't use a huge file just to make it sure it will work.
Thanks,
Jegger
Notifications
