w.william11
15 points
Posted on - 07/27/2016
Hello all,
I have a small Business set up. I have secured the Computers in the Offices with Windows Firewall. I don’t want to take any risk when it comes to Security. Do I Need a Hardware Firewall?
I have a small Business. Do INeed a Hardware Firewall?
I would suggest you to install a Hardware Firewall. Windows Firewall does protect your Computers, but as an Organization, you would need more protection. All of the users will not require access to 65535 ports. The Hardware Firewalls block the ports that the Employees don’t use, and do not need.
The users would use HTTPS:/443 and HTTP:/80 only. The Hackers cannot bypass the Hardware Firewall Devices. So, it’s better that you install it.
