I Have To Convert A File, How To Change Pdf File To Word Document. Any Ideas?
I have this pdf file which I have to change, how to change pdf file to word document. Any help would be great.
To convert it you can use two methods,
On adobe acrobat,
If you have a PDF file that needs to be in the Microsoft Office Word document format, changing it to this format means converting the file. With Microsoft Office Word, it can save an existing Word document in PDF format but it cannot open a file in PDF format. To convert your PDF file to Microsoft Office Word format, go to Convert PDF and other documents to Word.
This online tool converts any PDF file to the DOC format which is the old file format used by Microsoft Office Word from Microsoft Office 2003 going back. For Microsoft Office 2007 and newer, the file format used for Microsoft Office Word is now DOCX or .docx. If you want your PDF file to be in the DOCX format, go to Convert your documents to DOCX.
This second tool converts several documents including PDF to DOCX format. Uploading your document or your PDF to the service can be done in four ways: URL, Dropbox, Google Drive, and selecting it from your hard drive.
