I Have Tried To Call The File From The Database, And I Face A 0x800a0cc1 Error Message
What is the 0x800a0cc1 error? Describe the cause of the error and tell the steps to fix the error and also attach a snapshot of the error.
0x800a0cc1 error means that the item cannot be found in the corresponding to the requested name or ordinal.ADODB.Recordset that means the item cannot be found corresponding to the requested name or ordinal. It is a recorded error, and the user requests a file that does not exist. The error can be resolved using an SQL query.
When the user tries to look out for the database which is not present in the system, then this error message appears, and it can also occur if the user stores different values at the same location. When the value is called then the system doesn’t know to display which of the corresponding value, and it throws the error.
Check the query and the value to be called and this will help in troubleshooting this error message. The screenshot of the error is shown below:
