What is the 0x800a138f JavaScript runtime error? Explain the cause of the error and tell the steps to fix the error and also attach a snapshot of the error.
zanyap
I Have Tried To Construct JavaScript Code, And I Face A 0x800a138f JavaScript Runtime Error Message
0x800a138f JavaScript error is a runtime error that arises mainly from the ASP.NET application, and the reason for the occurrence of the code is the wrong coding construction.
The error is that txtFromDate and txtToDate are the server name of controls, not the client name, and if the JavaScript is located in an external JS file, then the solution will not work, but the user can give text fields a unique class name and modify the code. The 0x800a138f error message will appear like: “0x800a138f – JavaScript runtime error: Unable to get property ‘value’ of an undefined or null reference.” The simplest way to resolve the error message is to check for the wrong line in the script and correct it. The programmer has to use the correct sequence of code for the generation of the script.
The snapshot of the error is attached below:
