I Have Tried To Install A Windows Update, And I Face A 0x80096002 Error Message
What is the 0x80096002 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x80096002 error is a Windows Update Standalone Installer error in Windows 10 that occurs when the user tries to download Bit locker from the Microsoft Website. The error message code displays “Windows Update Standalone Installer; Installer encountered an error: 0x80096002, The certificate for the signer of the message is invalid or not found.”
BitLocker Drive Encryption is only built-in and supported in Windows 10 Pro and Enterprise editions. If you running Windows 10 Home, you were can’t download and install it. You need to upgrade to the Pro version. Windows Update Standalone Install Error 0x80096002 is caused due to misconfigured system files in the operating system. The user will get this error code when installing an incompatible software or a driver onto the PC. Install the software in compatibility mode, and the steps are as follows:
• Download the software setup file.
• Right-click on the setup file and click on the Properties.
• Click on the compatibility tab, check the box Run this program in compatibility mode for, select Windows 10 operating system from the drop-down menu, and proceed with the installation.
• Restart the computer and check for the issues are resolved or not.
Notifications
