I Have Tried To Install A Windows Update, And I Face A 0x80096004 Error Message
What is the 0x80096004 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x80096004 error is a Windows Update error that occurs when the user attempts to run the updates using the Windows Updates service. In some conditions, people may start seeing it after the successful installation of particular updates. 0x80096004 error occurs due to DNS conflict, incompatibility of internal Windows applications, or corrupted Windows Update components. If the user has a third-party antivirus installed on the system, it should also be considered one of the possible reasons.
The steps to fix the 0x80096004 error message are as follows:
Solution 1: Run Windows Update Troubleshooter.
Step 1: Click Windows Key+ X and select Control Panel.
Step 2: Type Troubleshooter and hit Enter.
Step 3: Select Troubleshooting and click Fix problems with Windows Updates.
Step 4: Select View All and click on Windows Update.
Step 5: Click Next then select Advanced.
Step 6: Select Run as an Administrator and select all the boxes.
Step 7: Click Apply and then on Next.
Step 8: Finally, Click on Close.
Solution 2:
Restart Windows Update Services
Step 1: Click Windows Key+ R, type “service.msc” and press Enter.
Step 2: Find Windows Update service and click on the stop button at the bottom of the Windows.
Step 3: Go to the C:\\Windows\\SoftwareDistribution\\ location and delete all the files.
Step 4: Again, open the terminal and start the Windows Update service.
Step 5: Restart the system, and try to run the Windows update.
Solution 3:
Reset the Windows Store.
Hold down Windows Key+ R, type WSReset.exe command and press Enter. The command terminal will reset the Windows store automatically.
