I Have Tried To Open The WMI Application; And I Face A 0x8004100e Error Message
What is the 0x8004100e error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x8004100e error occurs due to BSODs, systems freezes, and crashes in the system. We have system repair tools which can be used to fix this error by replacing the corrupted system files and DLLs, remove malware, and fix the damage caused by it; as well as this repair tool optimize the PC for maximum performance, and it occurs when Windows Update continuous fails to search for update and can’t install them. The other things responsible for this error are Windows Registry, Windows Filesystem, Virus, Corrupted files, Adware, Misconfiguration, Internet access, and Windows update service.
The steps to fix the 0x8004100e error are as follows:
Open the Control Panel and go to System and Security link. Select Windows Firewall and enable or disable the Windows firewall. Click on OK.
The snapshot of the error is shown below:
