I Have Tried To Send SMTP Mail, And I Face A 0x8009030f Error Message
What is the 0x8009030f error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x8009030f error is an application error that occurs while sending SMTP mail. The issues in the Windows installation or updation generate this error. The 0x8009030f error message displays that “Cannot send SMTP emails from any program(error 0x8009030f).”
The steps to fix the 0x8009030f error code are as follows:
Method 1:
Re-register the Mail app.
Step 1: Open System PowerShell and run as administrator.
Step 2: Type this command: Get-AppXPackage -AllUsers -Name Microsoft.windowscommunicationsapps | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register”$($_.InstallLocation)\AppXManifest.xml”-Verbose}
Step 3: Run the following command and see that the issues are resolved or not.
Method 2:
Run Built-in & Guided Walk through Windows Update Troubleshooter.
Hold down Windows Key+ X -> Click on Settings -> Click on Update and Security -> Click Troubleshoot -> Click on Windows Update -> Click Run the Troubleshooter.
Method 3:
Run SFC and DISM scan.
Hold Windows+ S and type cmd. Open a Command prompt and choose Run as Administrator. Now, type “sfc /scannow” and hit the Enter key. Wait until the scan and repair are finished.
Hold Windows key+ X and run the command prompt. Type “DISM.exe/Online/Cleanup-image/Restorehealth.” Insert media and type “DISM.exe/Online/Cleanup-image/Restorehealth/Source:C:RepairSourceWindows/LimitAccess.”
