I Have Tried To Sign-in Into The Windows, And I Face A 0x80090022 Error Message
What is the 0x80090022 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x80090022 error is a NTE_SILENT_CONTEXT that means the provider could not act since the context was acquired as silent. This error mainly occurs after updating the Windows; when the user tries to log-in with the fingerprint, this error appears.
The symptoms of the 0x80090022 error message are as follows:
• Frequently pop-up on the screen.
• The computer will work abnormally.
• Programs’ functions are limited.
• Windows system crashes and freezes.
The error code can be fixed manually as well as systematically by the application named as SmartPCFixer. The user has to download it and install’s within the system, then run the application and perform “Full System Scan,” and the application will find the problem then fix it.
The user can also fix the problem manually by the following methods:
Solution 1: Uninstall the recently installed application.
Go to the Start option and open “Programs and Features” in the Control Panel. Select the recently installed programs and uninstall it.
Solution 2:
Run System File Checker scan.
Hold Windows+ S and type cmd. Open a Command prompt and choose Run as Administrator. Now, type “sfc /scannow” and hit the Enter key. Wait until the scan and repair are finished.
