I Have Tried To Sign-in To The Apple ITunes Account, And I Face A 0x80090302 Error Message
What is the 0x80090302 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x80090302 error is an iTunes log-in error. When the user tries to login into the Apple iTunes application then this error occurs. This error occurs because of the corrupt files originating from the iTunes folder, and it can also occur by the conflict between iTunes and a pending Windows 10 update. The error message will appear: 0x800900302 error ‘Make sure your network connection is active, and try again.’ The main cause of the error is the conflict between Windows and the Apple program that makes the files of Windows corrupted and it disrupts the function of the program.
The solution to resolve this error is that the user has to reinstall the application and try again to log in and install the new application from the official Microsoft store.
Method 1:
Update iTunes to the latest application.
Method 2:
Running Windows Apps Troubleshooter.
Method 3:
Check your Internet connection.
