What is the 0x800a1391 JavaScript runtime error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
I Have Tried To Use The ASP .NET Application, And I Face A 0x800a1391 JavaScript Runtime Error Message
0x800a1391 JavaScript runtime error arises on the ASP.NET web forms platform, and the cause of the error is when the jQuery script file is not referenced in the corresponding web application. The steps to fix the 0x800a1391 JavaScript runtime error code are as follows:
• To render the EJ ASP.NET controls, refer to the base jQuery script before the Syncfusion scripts, as “ej.web.all.min.js,” and other scripts depend on the jQuery script file. The user must ensure that the order of adding script references to avoid errors with dependent script files.
• The simplest solution is to include the script at the end of the body section instead of in the head section, but this process will cause the document. Write a call to occur after the rest of the content.
The Snapshot of the error is attached below:
