I have trouble with firefox and chrome
Hi friends,
For some time, I have trouble with Firefox and chrome with the flash plugging. Firefox tells me he has planted, and that Chrome is blocked.
I tried uninstalling Firefox and chrome, and the flash plugging (it was installed adobe air),and reinstalling, but nothing works.
I'm running Win 7 update. Flash works correctly under IE9.
Answered By 0 points N/A #79561
Very few people know that there are types of Flash Players, yes, two of them. Plugin version for Firefox for latest browsers and An ActiveX version for Internet Explorer. So, if you want Flash plugins to work in Firefox you must install the plugin version, as explained above. To install the latest version manually. Go to "Adobe.com" and download the Flash installer.
On the other hand, chrome has deliberately blocked the flash because it shows lot of unnecessary ads while using a web site. So if you want to have flash on chrome, simply run the latest "Google Chrome 6.0.490.1 dev". It has "enable-click-to-play" command line switch. By which you can enable and disable flash by yourself.
